Paper Faced Metal Corner Bead Problem
Old 01-17-10, 03:09 PM
Hey All, If anyone has used this paper faced product from USG maybe you can help with my issue. While removing the excess mud under the tape on my corner bead I was distracted and missed a section. By the time I realized the error it was dry. Now I have a lumpy area under the tape and cant seem to figure a way out. If I try to sand it out the paper will be destroyed.
The only option I see is removing the affected section. Any thoughts??
Old 01-17-10, 05:08 PM
chandler's Avatar
Received 9 Upvotes on 8 Posts
Destroy the paper. Cut across the tape and the metal strips above and below your boo boo. Remove all the stuff that is causing the bulge, and start over with a piece the same size as the one you pulled off.
Old 01-18-10, 04:30 AM
Received 754 Upvotes on 659 Posts
If the metal part is ok, you can probably get by with just removing the paper portion and remudding that section. How big of an area is it?
Old 01-18-10, 06:32 AM
Its about 6 inch long section. Problem is its right near the end of the stick.
