Stomp ceiling - help
Old 01-30-10, 06:32 AM
K
Hello All! 1st time poster- YAY!
Anyway- I have decided to do a stomp ceiling in my family room. I did some drywall work, and I cant get the current design to match up.
I have 2 or 3 buckets of drywall plaster leftover... Can that be used?
If no.. what is the best type of plaster to use?
Also- do I need to worry about tape, mud and sanding the seams if before I do the stomp?
Stiff brush? Soft brush or do they make them specifically for that?
Whatever else anyone can tell me would be much appreciated.
Old 01-30-10, 02:55 PM
Received 754 Upvotes on 659 Posts
First you need to tape and finish the drywall. Texture can sometimes hide a poor finish job but it won't make the joints or screw heads disappear.
There are some that apply a stomp texture by using the brush straight out of the bucket, IMO it's a lot easier to thin the j/c and apply it with a roller - then stomp in the texture. The thinner the j/c is, the lighter the texture will be.
Most stomp ceilings use either a round texture brush or a crow's foot brush. Basically you stomp the texture into the wet j/c creating the pattern. I'm not sure if a texture brush is available at a big box store. If not you can get them at your local drywall supply house.
Old 01-30-10, 04:33 PM
K
thanks
thanks for the reply...
As for the type of "plaster" to use???
Old 01-31-10, 03:26 AM
Use regular joint compound, the kind that's premixed in a 5 gallon bucket.
