bathroom drywall
Old 04-06-10, 03:15 PM
T
bathroom drywall
I am renovating my bathroom using a solid surface shower. Is the best thing to use cement board at the shower and purple board everywhere else includin the ceiling?
Old 04-06-10, 03:22 PM
E
Im not sure what you mean by solid surface shower. Do you mean a preformed acyrlic or fiberglass shower. If so, then you dont need anything behind it, it cant get installed right to the studs. and purple board, i always call it green board. That should go in the ceiling of the shower and you can also put it behind the sink for good measure.
Old 04-06-10, 06:50 PM
T
I plan on using a corian type shower enclosure. What should I put on the wall there?
Old 04-06-10, 09:15 PM
E
well, i would do whatever the manufacture recommends, but i think that becuase these are sold as easy replacement and upgrades to older acrylic and fiberglass enclosures, i would say that it can be installed right to the studs. But thinking about it some more, i guess it needs to be glued into place, so sheetrock would work well too.
