Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Walls and Ceilings
Reload this Page >
Flammable styrafoam on ceiling - how to make safe
Old 05-19-10, 04:18 AM
I took possession of a fixer upper cottage this weekend. After compiling a list of things that need to be done I think my # 1 (for safety reasons) is remediation of the makeshift ceiling that has been installed throughout most of the building. It appears that a previous owner has taken sheets of styrafoam (not proper ceiling pannels) and has attached them to the rafters with pieces of wood trim. I believe the styrafoam sheets are 2 ft X 3 ft. So the ceiling ends up being framed in 2X 3 ft rectangles. I am assuming the sytrafoam is highly flamable and want to fix as soon as I can. I am thinking options may be a) tear down all of the trim and foam and replace with either drywall or perhaps beadboard - this would create a huge mess that I am not particularly keen on and time to get done is another problem or b) put drywall or beadboard directly over the current ceiling so the styrafoam is no longer exposed.
Thoughts??
Old 05-19-10, 07:10 AM
B
Received 47 Upvotes on 43 Posts
Check your local codes on required fire barriers and use of styrofoam in your building. Since they took that short cut I would be worried about what they did on say extending electrical boxes or insulation on the other side. Any electric or plumbing they did needs to be checked.
Bud
