Reinstall Soap Dish
Old 05-24-10, 07:09 PM
Reinstall Soap Dish
I have an old steel soap dish that was installed when my home was built (1981). The builder appeared to have simply cut a 4" square in the drywall, slid the soap dish in the hole then tiled around it.
I can't tell what material they used to keep it in the wall (a fellow at Ace Harware reckons they just put mortar on the back of it and around the edges).
To make matters worse, the soap dish doesn't fit flush up against the tile around it, so I can't just apply caul around it.
Do you have any suggestions how I can reinstall the soap dish without having to cut cut out part of the wall and installing new green board and re-tiling?
I basically have just a hole (nothing behind it) in the wall right now.....
Thank you!
Old 05-24-10, 10:27 PM
question is, do you want to do it right? My dad always said, if you can't do it right, don't do it at all. A little harsh, but true.
]I basically have just a hole (nothing behind it) in the wall right now
Does that mean, exposed studs, that's my take on it. If so, do you have wood to apply green board? If not, you are better off finding a stud and going from there. I know the tiles guys will have some great suggestions. Good Luck
