Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Walls and Ceilings
Reload this Page >
Need Drywall Help on 60's Bathroom remodel
Old 05-29-10, 09:47 PM
T
I am doing a remodel on a bathroom built in 1960. The walls were made of a layer of blue board with another layer of plaster. Due to the plaster smoothing out all the imperfections of the framing, the wall thickness varies from 3/4 inch to almost 1 inch.
I have gutted the bathroom down to the studs. Now I am looking at uneven studs that with a gap between the studs and the bathtub.
Somehow I need to get the cement-board to clear the lip of the tub. How do I do this when some of the studs hit the tub lip and some don't?
A few ideas I have thought of is:
1. Just hang 2 sheets of wallboard--the second will for sure clear the lip.
2. Somehow shim the studs to all line up right--I have no clue how to do this so that it will actually turn out right.
3. Nail new studs next to some of the old ones.
I am sure drywallers doing remodel jobs run into this all the time--any help would be greatly appreciated!
btw the room is 5'x8'
Old 05-30-10, 04:38 AM
Received 759 Upvotes on 664 Posts
Welcome to the forums!
You would either shim out the studs to make them fit or install new 2xs along side of them. If 2 layers of drywall will work, consider using 1/2" plywood strips. Don't forget the cement board needs a vapor barrier behind it.
Old 05-30-10, 05:44 AM
T
Thanks for the quick reply marksr. And thanks for the welcome =)
Looks like I have a lot of work cut out. I will try and get some pictures up after it's done.
