cost comparisions
Old 06-20-10, 08:16 AM
A
cost comparisions
We possibly will be building a new 3/2 home in north Florida in the nxt 8-10 momths and would like to know the comparetive costs between concrete block and brick; wood or steel studs; asphalt or steel roofing. I'm looking for the best bang for the buck and recognize there could be differences in labor costs also. I would appreciate anyone's input. Thanks, ahasbeen
Old 06-20-10, 11:11 AM
Received 785 Upvotes on 688 Posts
I'm not exactly qualified to give a good answer but I'll share my thoughts :
I used to live in fla and believe you'd be better off with block construction. Most houses there are typically built on a slab and wood framing put's the wood/siding too close to the ground [think insects]
IMO a metal roof would last longer. The intense fla sun is hard on an asphalt shingle. I've painted new homes that needed a new roof within 10 yrs. The fiberglass shingles seemed to last a little longer. I'm sure there is a big difference between the low cost and top of the line shingles.
I suspect both block construction and metal roofing would cost more
Old 06-21-10, 12:53 PM
Received 1,231 Upvotes on 1,179 Posts
Your best bet would be to talk to a couple local builders, your questions leave a lot of room for variables
As for bang for the buck, are you looking for short term or long term? A metal roof is going to cost more up front but last longer and likely save you money long term.
Old 06-22-10, 01:49 PM
A
Cost comparisons
Thanks mitch17....checking in with local builders is perhaps the best way to go, whick I will do.
ahasbeen
