drywalling a ceiling
Old 07-15-10, 05:14 AM
U
Getting ready to tear down the old drywall in my kitchen and replace with new 1/2" drywall. Do most professionals prefer paper tape or fiberglass self adhisive tape? Do you reccomend glueing and screwing seams and butt joints or will screws be fine? Any tips on finishing a butt joint? Should you taper the ends on your own? Any tips on finishing a butt joint will be helpfull! Thanks for your help!
Old 07-15-10, 05:59 AM
Received 754 Upvotes on 659 Posts
The fiberglass 'sticky' tape has a poor track record. paper tape will do a better job! Glue is almost always good although unlike the walls the glue [on the ceiling] won't allow you to use less screws.
Butt joints generally need to be floated out about 1' on each side of the joint. With the exception of this forum, I've never heard of anyone making their own taper/bevel on the drywall. IMO it's a bad idea - it can damage/reduce the strength of the drywall.
Old 07-15-10, 06:48 AM
Received 1,197 Upvotes on 1,152 Posts
Glue and screw is typical drywall installation these days
As Mark said, skip the mesh tape, go with the paper
Old 07-15-10, 06:52 AM
Tolyn Ironhand's Avatar
Received 707 Upvotes on 600 Posts
Never seen much glue used with drywall but screws is the way to go. Also IMO I always use 5/8" drywall on the ceilings no mater what the framing spacing. Reduces any chance of sag.
Old 07-26-10, 12:12 AM
E
glue and screws are both widely used, yet personally, screw is a better choice.
