Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Walls and Ceilings
Reload this Page >
Wainscoting on plaster walls in bathroom
Old 07-18-10, 09:56 AM
N
Hello,
I am new to home renovations and I am looking to put wainscoating mid way up the wall in my bathroom using a bead board kit with the baseboard and top moulding.
My home was built is 1939-1940 and on the wall there is tile which I am currently removing. The wall behind the tile is plaster. When I remove the tile some of the plaster comes with it.
What I would like to know is what do I patch the wall with and can I use adhesive and a finishing nail gun to install the wainscoting?
I was not sure if the finishing nails will hard the older plaster or if using this method the wainscoting will be secure.
The studs are 2-3 inches behind the plaster so I won't be able to secure the wainscoting to the studs.
Thank you!
Tracy
Old 07-18-10, 10:29 AM
chandler's Avatar
Received 9 Upvotes on 8 Posts
Welcome to the forums! I am assuming you will be installing chair rail over it. Correct me if wrong. You can possibly skim coat the plaster with a plaster repair material and install the panels using PL adhesive or even Power Grab, but I'd still chase the seams and edges with a finish nail or two. Not for permanent holding, but until the glue sets up.
Old 07-18-10, 12:23 PM
N
Sorry to need to ask, what is PL adhesive?
Yes I was going to put up chair rail. The wainscoting paneling where I have about 1 foot sections of paneling to put in tongue and groove.
Will the finishing nails harm the old plaster?
Old 07-18-10, 01:41 PM
chandler's Avatar
PL paneling adhesive is a brand name, but any similar adhesive made for paneling will be fine. PL is used most often. I think the nails shot with a pneumatic nailer will move so fast it won't harm the plaster. Power grab adheres instantly without nails.
