Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Walls and Ceilings
Reload this Page >
exposed paper tape during sanding--can I prime it
Old 07-25-10, 03:19 PM
G
I sanded a little too far in a few high spots on some of my butt joints in the newly sheetrocked ceiling. They are small spots like a nickel or so in size.
Can I go ahead and prime over this? Will I see a big difference in the surface if I do this? Or do I need to apply another layer of mud, let it dry, sand again, etc. before I can prime?
Thanks!
Old 07-25-10, 03:22 PM
P
Temporarily Suspended
Prime it, see how it looks. You can always put another coat of compound if necessary.
Old 07-25-10, 05:32 PM
XSleeper's Avatar
Received 1,744 Upvotes on 1,568 Posts
I would definitely apply more mud.
Old 07-26-10, 04:16 AM
Received 754 Upvotes on 659 Posts
If the tape has 'fuzzed' up some you'll need to cover it with mud, otherwise primer might be ok.
Old 07-26-10, 05:43 AM
Received 1,197 Upvotes on 1,152 Posts
Just remember anything you see with primer on is going to be even more obvious with paint on the wall - if the surface is any different, you're going to notice it
Myself, I'd apply more mud but it may work out just to go ahead and prime it
Old 07-26-10, 06:15 AM
G
Thanks, everyone!
I went ahead and covered it again with a thin layer of mud. Better safe than sorry. Ceilings are a pain in the butt and I don't want to re-do anything later after it's all painted.
