suspended ceiling grid question
Many installation methods used on the net include installing the grid for 2'x4' and then putting in 2' tees for a 2x2 ceiling.
Is there a problem with installing the support tees on 2' centers and then just snapping in the 2' tees to give the 2x2 grid. Do you know if there is a reason why I should begin with the 2x4 grid?
One reference I found with one of the (professional looking) materials estimate calculator says to either use 4' tees or 2' tees, not both, so I dunno
Thank you,
Bob
Thank you,
Bob
I think it's easier to square things up when you keep your main T's on 4' centers. When they are 4' apart, you can make a 4' square... check it for squareness... divide it in half with another 4' divider, then divide that into smaller pieces with the 2' dividers.
I have always used a downloadable layout/materials calculator program that Armstrong has/had on their website to calculate drop ceiling needs. Usually do it just the way their program suggests unless I want to fudge the layout one way or another for some reason.
As XSleeper says it is easier to make 4' squares then subdivide them. It also makes for a sturdier install, since your movable joints are on 4' centers rather than 2' all over.
