walls
Old 12-08-00, 06:36 PM
I recently put sticky-tack stuff on the walls of my apartment to decorate. I have tried to take it off by scraping, but i'm ruining the stucco. I need a way to either remove the tacky stuff or cover it, and cheaply.
Old 12-09-00, 12:39 PM
If it's stucco, just add to the texture with joint compound over the sticky tacky stuff. You'll have to paint though. Don C.
Old 12-09-00, 09:22 PM
To take off your sticky stuff, you will need to use something with an alcohol base. Even rubbing alcohol. Look for a glue remover at your store. They usually come in bottles.
Old 12-13-00, 06:26 PM
Try using WD-40 on the sticky stuff. It is a good general purpose solvent.
