Drywall texture gone wrong!
Old 01-05-11, 12:42 PM
K
Help! Husband & I bought our home over 2 years ago and have made many changes so far. One of them was covering our wood paneling with a drywall mud texture. Turns out, that was a horrible idea becuase it has warped over time, cracked, and is now peeling off. We have spots in our living room where you can see the paneling underneath.
My question is what do we do now? Having someone come in and drywall the place is the simplest idea but also the most costly. Another idea is to scrape the texture off (or simply peel it off in some areas) and just paint the paneling. But my husband is worried that we won't be able to get all of the texture off.
Anyone have experience with this? Any tips for scraping this mess off with the least damage done to the walls as possible? We are considering every option at this point.
Old 01-05-11, 12:51 PM
Received 1,197 Upvotes on 1,152 Posts
Did you prime the panelling before you put the mud on? It sounds like you have an adhesion issue
I'd scrape off what you can, prime and then do it again
Old 01-05-11, 12:52 PM
bish80's Avatar
You should be able to scrape the drywall off fairly easily. Drywall compound comes off with water, so after you scrape it, a sponge should do the trick. I would try to remove a small sample to make sure that there was nothing else on there.
Is there knots in the paneling or maybe is it that paneling from the 70's that came in 4 X 8 sheets with groves cut into it every couple of inches. I have seem house where they just painted it white and it looks fine for years.
Old 01-05-11, 01:03 PM
K
I'm not sure if priming was done, we had a contractor friend do the job while we were at work. We definitely have adhesive issues. We are in southern Louisiana with all the heat & humidity so I'm not sure I would go this same route again. I thought maybe they didn't sand well enough so the texture did not stick to the glossy wall underneath.
Bish- yes we have the tacky 70's faux wood paneling with grooves, also very glossy.
So if I were to scrape the texture off (assuming it comes off without damage to the paneling), should I sand again, prime, and then paint?
Also what would you use to scrape the stuff off?
Old 01-05-11, 02:07 PM
Received 754 Upvotes on 659 Posts
Use a wide putty knife [4-6"] to scrape if off. As mentioned getting the j/c texture wet will aid in the removal. IMO it's never a good idea to apply j/c or texture over paneling - primer and paint is a better option.
