Popcorn ceilings
Old 02-16-11, 04:07 AM
chandler's Avatar
Received 9 Upvotes on 8 Posts
Popcorn ceilings
I know we have visited this several times in the past, but as I usually shy away from messing with popcorn, my experience yesterday was pleasant, however. We had installed a beam in a basement to allow for more room, and, naturally some of the popcorn ceiling was damaged by our false walls. Owner wasn't particular. Asked if we could just remove it. Naturally, very macho, I said, sure we could.
Set things up about 8 yesterday morning....two spray bottles.....two sheetrock knives.....two small boxes and a trash can. In less than an hour we had a 12 x 40 room rid of popcorn with little floor mess!! I even amaze myself. Just catch all the fallout in the boxes and dump them in the can....very little mess.
Old 02-16-11, 04:30 AM
Received 758 Upvotes on 663 Posts
Ain't it nice when a plan comes together
Unpainted popcorn is always easy to remove although it's not always so easy to not make a mess. The more humidity it receives, the easier it is to remove and the harder it is to paint Glad it worked out well for you.
Old 02-16-11, 10:25 AM
Received 1,198 Upvotes on 1,153 Posts
Easy take down, how you kept the mess down is the real accomplishment
Old 02-16-11, 02:36 PM
chandler's Avatar
I've been putting off our two bathrooms (why popcorn in a humid bathroom?) for over 11 years, now because I just didn't want to have the mess. I'll have it done by noon Saturday, betcha!! Gotta find someone who paints
Old 02-16-11, 02:47 PM
You try talking Mark into it with the promise of a feast?
Old 02-16-11, 03:09 PM
chandler's Avatar
Froglegs and the like.....hey, he would be at home!!
Old 02-16-11, 03:19 PM
Hopefully the popcorn hasn't been painted. If it has you'll need to scrape first and then wet the texture.
Frog legs - yummmm......
Old 02-16-11, 03:33 PM
chandler's Avatar
No it's just sitting there.....at least the part that doesn't fleck off when you take a hot shower. Looks terrible. I'm gonna do it!!! I am!
Old 02-26-11, 02:50 AM
B
Vaulted Popcorn ceilings
I understand that its a real pain to paint or spray popcorn. Instead of the wet mess, can I scrape or hard brush the popcorn off and then paint as I do my walls?
Old 02-26-11, 03:15 AM
The biggest issue with painting deteriorated popcorn is the moisture in the latex paint will dissolve some of the popcorn making it turn loose. If you do paint old popcorn texture it's best to use an oil base primer first. If you attempt to paint without the primer, it's best to apply the paint quickly and not go over any areas twice. If you need to touch up any spots that didn't cover [or got missed] - wait for the paint to dry first. There is also the danger that some texture may turn loose as you are painting it
almost forgot welcome to the forums Bottomdweller!
Old 02-26-11, 04:40 AM
chandler's Avatar
I agree with Marksr, but the "mess" you refer to, is contained to a box you carry with you. It doesn't fall on the floor. Some does, but drop cloths keep it clean. Only experience with painting popcorn resulted in removing it all, anyway, as it pulled off with the roller and made an even bigger mess. Work in a 3' square area, then move on. Wish I had done it 10 years ago!
Old 03-15-11, 05:45 PM
L
Prep after de-popcorning???
Caveat: I have never removed popcorn from a ceiling, but I am being surrounded by popcorn ceilings even as we speak (and it's beginning to annoy me!).
After you scrape off the popcorn, can you paint right over it? I would think it would be textured and need some sort of prep before painting.
Len
Old 03-15-11, 06:47 PM
chandler's Avatar
Len, a big reason for spraying popcorn back when it was popular to do so was to alleviate the final coat of joint compound. I guess they figured labor savings was important, and "hey" we got a new toy to play with. You will find the seams may need one more 12" stroke of thinned joint compound, then a light sanding along the edges before prime. What you have left after wetting and removing the popcorn is nothing but probably unprimed sheetrock, really! There won't be any texture to deal with.
Oh, welcome to the forums!
Old 03-15-11, 07:32 PM
L
Thanks, Chandler. That sounds right...we will find out what's needed once the popcorn is off.
Old 04-08-11, 09:17 AM
W
Wait a minute...all it take's is spray bottles (Water I presume??) and a little elbow grease and popcorn ceilings disappear?
I'm feeling pretty stupid right now.
Old 04-08-11, 09:31 AM
Yep, that's pretty much it....... but if the popcorn texture has been painted it can be more of a job. On painted popcorn you need to scrape first so when you spray the water on the ceiling it will have some unsealed places for the water to penetrate and soften up the texture. Once the texture is removed you'll have to do some drywall repairs. This can be as little as a few minor touch ups or worse case scenario - skim coating the ceiling.
