Transition between new and old drywall
Greetings!
Time to start putting the kitchen back together and I'm trying to decide on the best way to handle the difference in thickness between the original button board/plaster ceiling and walls and the new drywall I'll be installing. The original walls are about 3/4" thick.
Fur the studs out with shims?
Double up on the wall board?
Many thanks for your insight,
Mark
Mark
Yes, whatever works. If anything keep the new work a little shy. It is easier to fill it than try to fill on the other side if the plaster is shy. Get as close as you can so you have as little fill as possible.
