Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Walls and Ceilings
Reload this Page >
How to connect a porch swing to my cealing in my living room.
Old 05-09-11, 05:00 PM
B
I would like some one to help me hang a porch swing in my living room with out cracking my drywall or damaging my cealing.
Old 05-09-11, 05:29 PM
tldoug's Avatar
Here's a solution that will satisfy your desires and you don't even have to hire someone to install it.
Old 05-09-11, 05:47 PM
B
Thanks but that will take up to much room.
Old 05-09-11, 06:29 PM
ray2047's Avatar
Do you have 2X4 or 2X6 ceiling joists or is there floor joists for a room above? If ceiling joists how close to a wall do you want to put the swing? Do the ceiling joists run parallel or perpendicular to that wall?
Old 05-10-11, 05:58 AM
B
I have 2X6 joist 1 story house. Its not going to be bye a wall more less in the open. the joists are running noth to south and the swing will be running east to west.
Old 05-10-11, 07:54 AM
ray2047's Avatar
I'd sister the 2X6 wall to wall and use 6 inch long 1/2" screw eyes. Might be over kill but better safe then sorry.
Old 05-10-11, 08:58 AM
B
Thanks might give it a try.
Old 05-10-11, 09:25 AM
B
Do you think some 2X4s from the joist to the rafters would strengthen it
Old 05-10-11, 09:51 AM
ray2047's Avatar
Yes. Good Idea but I would use one on either side of the joist and bolts all the way through. Maybe a 2X6 so it was wide enough you could put a bolt on either side of where the screw eye goes in. That would sandwich the joist between two boards and help keep from splitting where the screw eye went in.
Old 05-10-11, 10:06 AM
Gunguy45's Avatar
Super Moderator
Received 5 Upvotes on 5 Posts
"with out cracking my drywall or damaging my cealing."
Put 300 lbs or so suspended from two 1/2 bolts...and I just about guarantee you'll get some flexing which will cause cracks.
Old 05-10-11, 10:57 AM
B
Thanks I think I will try that.
Old 05-10-11, 11:00 AM
B
Hey Gunguy do you have any suggestions on how I can make it work.
Old 05-10-11, 11:19 AM
ray2047's Avatar
Ideal way would a beam separate from the ceiling joists resting on wall with pads raising it an inch or so above the sheet rock But getting the beam in the attic could be a major problem. I actually did something similar by using 2X10s cut to six foot length and sistered with three foot overlaps at the joints. Whole thing moved into the attic in pieces and bolted together in the attic. NOT recommending that.
Old 05-10-11, 11:42 AM
Gunguy45's Avatar
Super Moderator
All the info here is good...I was just saying be prepared for some cracks.
btw...this isn't a rental I hope?
B
Thanks guys for the help would like to get more suggestions. So if you can think of somemore ways please let me know. Im gona soak up all the knowledge I can before I attempt the job.
Old 05-10-11, 11:46 AM
B
I own the home. I bought it about a 3 weeks ago.
Old 05-10-11, 12:18 PM
Gunguy45's Avatar
Super Moderator
If you have plaster walls (found in older homes), it's more brittle than painted sheetrock and will crack.
Old 05-11-11, 08:30 AM
B
Its sheetrock. The swing would look good in my home if I can just figure out how to stableize it where the cealing want move.
