Toggle bolt question
I've installed a toggle bolt to help with holding up a book shelf I got at IKEA. I might've put a little too much weight on the shelf, so now there's a bit of a bulge coming from the toggle bolt through the drywall. I'm afraid that if I keep it this way the bolt will shoot right through the wall and the shelf will come crashing down.
The simplest choice would obviously be to use less weight - which I've done. However it's still showing a bit of a bump there so I think the damage is worse with any weight.
The only solution I can think of is to have a much larger toggle bolt that will disperse the weight over a larger area of the drywall to alleviate the problem. But I don't know what's available out there to do that.
Anyone have a better solution that maintains that clean look (and only that)?
Welcome to the forums!! The shelf system would span over at least two studs if it is 33" wide or wider. Have you tried putting cabinet head screws directly through the cabinet (predrilled hole) and into studs?
No. There is no cabinet or any no studs in the area - just drywall. That's why I'm using toggle bolts.
How wide is the shelf? Larry was referring to cabinet screws not a cabinet. The shelf really needs to be secured to a stud - they are typically at 16" intervals although occasionally at 24" You'll need to fix the bulge to make it go away. A larger toggle bolt won't fix that, it might even make it worse.
I have secured IKEA shelves with just 2 standard wall board anchors even when they had doors without any issues. Is your shelf level front to back, and is it by any chancing sitting on carpet that is causing it to move forward as it is compressed with weight, and if not is it level to begin with? I am trying to understand why you are getting so much forward movement on the shelving.
