12 foot header
Old 07-14-11, 08:05 PM
T
12 foot header
Hello all. I want to remove a load bearing wall that is 12 feet long. What size lumber should I use? Would double 2x12s be enough? And do I need two jack studs on each end for support or would one be enough for that long of a span? Or would I be better off using double 12 inch lvls?
Old 07-15-11, 04:53 AM
W
Received 60 Upvotes on 52 Posts
Header
You have not told us what is above the load bearing wall.
Have an engineer look at your project and make a recommendation.
Old 07-15-11, 12:55 PM
chandler's Avatar
Received 9 Upvotes on 8 Posts
Welcome to the forums. As Ken said, an engineer is a must in this instance. We can't give such advice, since we are sitting hundreds of miles from you with no more insight than you gave us. I would recommend LVL beams rather than dimension lumber for a header.
