Inside corner sheetrock question.
Received 0 Votes
Do I use the finished edge where it tapers off for the inside corners or do I cut that off to the actual 1/2 in size of the sheetrock? thanks.
If there is a choice, I would use the finished tapered edge out away from the corner to match up with another finished edge and put the cut edge in the corner. Nothing wrong with using either in a corner, just better to use the tapered edges out on the flat.
Bud
Bud
