Quasi Babygate wall mounting help
We own this
Amazon.com: North States Superyard Classic XT Gate Play Yard: Baby
It is not intended to be mounted on walls. By looking at it, do any of you think there is a way I can do it, and if so, how I would I go about it. I would be mounted right into the dry wall. Thanks for the help.
Temporarily Suspended
I'm not quite sure what you want to do but you would need to use something as a furring strip. White vinyl 1x4s would look nice. If you can't screw them to a stud, anchors or toggle bolts may work. Then use a metal bracket around the gate posts.
Thanks
we have a den with no doors attached about 11 ft. long... the gate pictures here is supposed to connect but we want to open it all the way and attach it to the wall. Our daughter is starting to pull and stand up on the gate we have now and we need something secure... thanks for the advice...
