Repair water leak drywall damage
Old 09-12-11, 09:23 AM
Hello,
I had a small leak on one of my skylights (now repaired). I ended up with a small water stain on the drywall, at the connection of the ceiling and wall. The stain is roughly 8”x2”. The drywall feels solid and firm and doesn’t feel damp. The water stain was there for a few months and slowly got worse with each rain. I don't think there was a lot of water leaking, but enough to stain the drywall.
What is the correct way to repair this? Should I cut out the drywall and let this area air-out for a period? I’m pretty sure I want to open the drywall to make sure I don’t have more damage that I can’t see.
Thanks for the assistance.
Scott
Old 09-12-11, 10:12 AM
Received 757 Upvotes on 662 Posts
If the drywall is still solid, I wouldn't think there would be a need to open it up. I'd coat the stain with a solvent based primer - that will seal the stain so it won't bleed thru latex paint.
If you are dead set on opening it up, take a utility knife and cut out the affected area. If you do a decent job of cutting out the old and the drywall is solid - you can reuse that piece to patch the hole.
Old 09-12-11, 10:25 AM
Received 1,197 Upvotes on 1,152 Posts
If it feels solid, I'd just seal it with an oil based primer and then paint, as Mark suggested.
Your call if you want to open this up, Mark gave you a good procedure for that as well.
