board and batten wainscoting
I was considering beadboard wainscoting for my bathroom, but have decided that "board and batten" would be more fitting for the house (1912). Can anyone recommend an on-line (or off) resource for installing board and batten wainscoting?
Thanks very much.
Thanks very much.
HELLO
I just did a big house in San Fransico with board and bat.
we removed the base, used 3/8" x 4' x the hight of the wainscot plywood shop birch for the boards and 1/4 x 1 1/2 in poplar for the bat. you need to lay out the bats before you start so the brake in the pkywood falls under a bat before we installed the bats we installed the base and chair rail to a leavel line and then the batts cut to fit as needed..installed a bat in each side at the corners and casings...Good Luck...
