Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Walls and Ceilings
Reload this Page >
cause of mold/bubbling paint on bathroom ceiling?
Old 11-06-11, 12:58 PM
The ceiling paint on my 1st floor bathroom started bubbling and it has steadily gotten worse, now it has mold over it. (please see the images I took.. sorry they're sideways)
Directly above this bathroom is a 2nd floor bathroom shower. I know this bubbling/mold is caused by water/moisture., but I'm unsure as to which of the following possibilities is the actual cause:
Possibility #1: it's caused by moisture/humidity in the 1st bathroom itself, considering the mold spot is almost right above the shower. perhaps it's just poor circulation in this bathroom?
Possibility #2: it's caused by a leaking pipe (or non-waterproof shower floor?) from the shower from ABOVE on the 2nd floor.
I would greatly appreciate anyone's opinion or advice of expertise on this problem, as I don't want to have to rip open the ceiling if the issue is only poor circulation and can be solved with just a better fan. If the cause IS a leak from above, do you recommend opening the ceiling up from below or completely demolishing the shower floor from above? (only bc the issue may be that they didn't put a waterproof layer under the shower floor?)
Thank you all in advance!!
Old 11-06-11, 03:58 PM
airman.1994's Avatar
Received 8 Upvotes on 8 Posts
Do you use your bath fan for at least twenty minutes after showering
Old 11-06-11, 06:00 PM
No I usually don't leave the fan on after showering. The fan is on during a shower and then afterwards I leave the bathroom door open to air it out.
Old 11-07-11, 04:29 AM
Received 754 Upvotes on 659 Posts
How old is your home? another possibility is latex paint over oil base enamel ...... but I agree with airman - the exhaust fan needs to be run longer!
Old 11-07-11, 07:35 AM
Received 1,197 Upvotes on 1,152 Posts
Yes, run the fan for a longer time. That said, there could be a leak from the bathroom above, I had one when I moved into my house and it caused the paint on the ceiling in my shower stall to fail.
