Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Walls and Ceilings
Reload this Page >
Need Help With Matching Ceiling Texture
Old 12-01-11, 10:22 AM
Exclamation Need Help With Matching Ceiling Texture
Does anyone know what was used to get this texture in ceiling?
http://i1236.photobucket.com/albums/...n/ceiling3.jpg
Thanks
Jimmy
Old 12-01-11, 11:02 AM
Received 1,197 Upvotes on 1,152 Posts
Welcome to the forums.
Your picture did not come through, try this: http://www.doityourself.com/forum/el...-pictures.html
Old 12-01-11, 11:47 AM
Thanks Mitch17. It's fixed.
Old 12-01-11, 03:09 PM
Received 754 Upvotes on 659 Posts
It looks like the j/c was thinned down and then rolled on, then a brush or sponge was used to pat down the j/c. Doesn't look very uniform so they probably used a sponge. You can experiment with it, thinner j/c = lighter texture, thicker j/c = heavier texture. You can practice on some cardboard. If it isn't right after it's on the ceiling you can scrape it off [wet] and start over. Dry, it can still be scraped/sanded.
Old 12-02-11, 01:47 PM
coops28's Avatar
That is called "stomp" texure. It is done with a crows foot brush. It has long bristles mounted on a wood frame. You can get one at home depot or lowes or wherever. Make sure you thin you mud down a lot. It looks really thin.
