texture on panel
Old 01-12-01, 08:26 AM
I have panel on my wall. I was wondering what I can put on the wall to give them a little texture. Then after I put that on I would like to paint the walls. I was thinking of using a paint roller and all purpose joint compond. Is this a good or bad idea. Please let me know before I make a big mistake.
Thanks in advance
Old 01-13-01, 06:07 AM
some help
Hello
Go to the paint department of you home senter and get Stipple paint and Stipple roller...You paint it on if you want more of a testure you roll it before it dry also..they have other things that work as well....joint compound does not work the roller slides and works you hard and then it looks bad so don't even try>>>Good Luck
