Paper ripped off drywall.
Old 12-24-11, 12:12 PM
B
While removing the base molding in my bathroom, some of the paper ripped off the drywall. What prep is needed to paint over the drywall where the paper was removed? Thanks.
Old 12-24-11, 12:49 PM
Gunguy45's Avatar
Super Moderator
Received 5 Upvotes on 5 Posts
You need to seal the areas exposed by the ripped paper first...using something like Gards (there are other comparable brands) or an oil based primer. The smooth the area with spackle for small areas or sheetrock compound for larger areas. Sand if necessary and check the surface for flatness using a large mud knife or flat metal edge like a level. Prime the compound with a quality primer, then paint
Old 12-24-11, 12:56 PM
airman.1994's Avatar
Received 8 Upvotes on 8 Posts
Just a skim coat of mud is all that's needed
Old 12-24-11, 01:21 PM
Gunguy45's Avatar
Super Moderator
Incorrect....every advice site available on a search recommends priming exposed paper/gypsum.
brihen...just do a simple search for "repairing torn drywall paper". Step by step with pictures will show up.
Old 12-24-11, 01:51 PM
Received 753 Upvotes on 658 Posts
You need to prime the exposed gypsum first! If not the water in j/c or latex primer can cause the gypsum to swell and will often make the surrounding paper to peel.
Zinnser's Gardz is the only latex based primer I'm aware of that is suitable for sealing exposed gypsum. I generally use an oil base primer but mainly because I'm old school and almost always have some solvent based primer on hand.
Once the skim coating is done you need to prime again but most any latex primer will be ok .... but you can use the gardz or oil primer if you so desire.
Old 12-24-11, 02:47 PM
B
Post
Thanks everyone for the prompt replies and info.
Old 12-26-11, 06:04 AM
Received 1,197 Upvotes on 1,152 Posts
Exposed gypsum must be sealed before applying joint compound, as Vic and Mark stated.
