drywall
drywall
Soon I am going to put up drywall in an addition that I am having built. The length of the room is about 25' and the width is about 11'. The ceiling height is just under 8'. What is the correct and best way to hang the drywall, vertically or horizontally?
I'm a firm believer that drywall should always be hung horizontally, unless it's on a short wall (less than 4') where you could eliminate a seam if hung vertically. But it depends who is going to finish it and what their preference is.
You have WAY less trouble with running off the 16" OC layout when you hang it horizontally. It only takes a fraction of an inch to really hose you when you hang vertically. The layout could be off... or something is out of plumb and you're hosed.
Glad to help. When hanging drywall horizontally, you should always try and use sheets that are as long as possible/practical so as to reduce the number of butt joints. So for your 11' wall, use 12's.
I also believe in hanging the drywall horizontally. It's easier to get a flat looking wall that way and it saves your back when taping and finishing the joint
Received 0 Votes
mitch17 mentioned drywalling the ceiling. I have a youtube video on drywalling ceilings that you
might want to take a look at. The method described in the video shows how to do the ceiling drywalling by yourself using a cheap little jig. Not sure if I am permitted to post a link here but if you want to search nlinventor channel on youtube you should find the video or perhaps search "drywall ceiling" on yt.
it's almost fun.
If you aren't able to rent the lift, you can make a T out of 2x4s. Make the T about 1" shorter than the ceiling height. You prop one end of the drywall up with the T and then secure the side your holding before moving to the end that's propped up. Not as easy as the lift but it works.
Nahhh, just younger. Ever notice in the big towns where they have dedicated hanging crews - none of them are 30 yrs old. I know what you mean about a change of pace
