Hessian Wallpaper Backing
Old 05-02-12, 09:31 PM
P
Hi all,
I have just purchased my first property and am looking to start some DIY renovations.
First of all I am wanting to remove the old wallpaper, and paint the walls.
the wallpaper is easy to remove but it has a hessian backing and I am wondering what the best option would be from here.
I have heard I could use a product called XIM, which is a thick primer that might cover the hessian, but I have also been told I should paint an undercoat and skim the wall with plaster.
I am fairly good with basic DIY, but have never plastered before and would like advice on which is the best option, or if their is a better option?
Cheers
Old 05-03-12, 04:10 AM
Received 753 Upvotes on 658 Posts
Have you tried wetting the backing? Often getting the backing wet will somewhat dissolve the glue allowing it to be scraped off.
Old 05-03-12, 06:06 AM
Received 1,197 Upvotes on 1,152 Posts
Long term, you're probably going to be better off removing the backing, even if you damage the wall underneath here and there (and we can help you with that if you do )
Old 05-03-12, 12:08 PM
P
I agree, but unfortunately the previous owner did a quick patch up job and plastered over some of the wallpaper already. Also, the burlap is completely covered in a rock solid adhesive and would be almost impossible to remove.
Old 05-03-12, 12:14 PM
If you can't remove the backing, coat the wall with either an oil base primer or Zinnser's Gardz. Then apply a thin skim coat of joint compound, sand, prime [latex primer is ok] and it should be ready for paint.
Old 05-03-12, 12:21 PM
I'm with Mark if you can't get the backing off the wall.
Old 05-03-12, 12:55 PM
P
Ok, Thanks for the advice. I think I will do that and see how I go. Its my first time plastering so it should interesting.
Old 05-03-12, 02:15 PM
P
This is what the hessian backing looks like.
Old 05-09-12, 12:36 PM
P
All done
I ended up having to strip down the painted hessian burlap, then sand, then seal with oil based sealer. then plaster, then skim coat, then sand, then skim coat again, then seal with water based and now I am finally ready to paint and wall looks great. But, what a nightmare of a job,
I probably saved myself a few hundred for a contractor.
Old 05-09-12, 01:27 PM
Yeah, sometimes you have to assume your labor rate is $0 on a DIY job but at least you get to say you did it when you're done
Old 05-09-12, 01:42 PM
.... and you now have some experience if this type of situation ever comes up again
