closing in arched opening
Old 08-24-12, 09:09 AM
I just need advice on how to fill in this 10' archway?
I want to turn the formal dining room into a bedroom.
so I'm gonna install a door and fill in the rest w/ wall, but i'm kinda stuck on what to do at the archway and/or how to do it?
Old 08-24-12, 09:30 AM
Received 753 Upvotes on 658 Posts
Welcome to the forums!
You'll need to remove the drywall over the arch and the edges [corner bead] of the opening. Once it's opened up you'll see how the arch was framed. It will either be all framed with dimensional lumber or some plywood may have been used. You can then determine if it makes more sense to remove the arch and reframe or just frame out the opening [bottom and top plate with 2xs on the side - the arch is just a gap that the drywall can span]
Old 08-26-12, 06:38 PM
P
Temporarily Suspended
Why does he have to remove the drywall? I would just frame inside it.
Old 08-26-12, 07:17 PM
chandler's Avatar
Received 9 Upvotes on 8 Posts
I'd just frame it up, 'cause when you go to sell the house you will need to turn it back into an attractive dining room. In building this "bedroom" are you including a closet? How accessible is it to a bathroom? Are you doing it out of necessity (xtra kids) or for aesthetics?
Old 08-27-12, 05:11 AM
Without removing the corner bead it would be difficult to smoothly finish the new drywall and it's better to remove the drywall on the return so the new studs are secured directly to wood..... but Larry makes a good point about needing to turn it back into a dining rm at a later time!
Old 08-27-12, 05:56 AM
P
He sure did make a good point. Molding can be used to cover those edges, in the meantime.
Old 08-27-12, 05:04 PM
chandler's Avatar
That's why there's 12" mud knives Make it work!! Feather it .
