Converting tub to shower. Issues with window in shower.
Hey everyone.
FINALLY going to begin my tub/shower remodel now that I've got some free time. Pretty simple job; tearing down the drywall that surrounded the tub, adding a shower line, and tiling the walls. My only real issue (at the moment, before beginning construction) is the window. I haven't removed all of the drywall around the window, but from what I have removed has me confused.
It looks like there is a piece of drywall underneath the window supporting it. Also, there's a flexible aluminum sheathing that frames the window( no clue what you'd call it). When removing the drywall it looked like the aluminum was ingrained into the drywall. My question is, how do I waterproof this window properly? I was thinking redgard around the entire window, 1/2 backerboard should fit underneath the sheathing, nail it to the backerboard, and then cover with plenty of thinset & fiberglass mesh tape. Please let me know if I'm way off the mark. I'll get some pictures up later if they'll help.
Thanks all
Thanks all
Naturally a picture is worth all the words you can speak, so if you can, post a picture of the window area (not close up, we know what sheetrock looks like), so we can see what you see. In addition, don't forget you need to run a new drain line from the shower to the main drain. Your current line is probably only 1 1/2" in diameter and it needs to be 2".
Alright, after talking with my buddy who's got more know-how than myself, I realized I'm going to need to remove that sheathing, as well as the drywall that is framing the window and replace with cement board. My question; Will I need a aluminum frame like that with cement board, or will i just mud and tape those areas?
Pics:
Pics:
Yeah, what you have is a "return" sheetrock casing. The metal and all the sheetrock inside the window frame needs to go. That way you will have a new surface to which you can attach your cbu. It appears the original installer made his apron out of sheetrock. You will probably want to make your tile flush to the window and allow the bottom tile to protrude slightly for a drip edge, or use bullnose around all the window for a flush look. Elevate the back of your bottom window tile for runoff slightly, too.
