shortening a load bearing wall
Old 10-29-12, 12:43 PM
B
i am looking to shorten this wall by 9.5 inches. i have added a new 2x4 for support. is this ok?
let me know i attached some pictures
Old 10-29-12, 12:48 PM
Received 1,197 Upvotes on 1,152 Posts
So the wall is going to stop nearly a foot short of the beam yet the 2x4 will continue to the beam?
I don't see where this is going, what are you trying to accomplish?
Old 10-29-12, 12:58 PM
B
if you look at the first picture, i want to remove the section of wall my level is resting against.
Old 10-29-12, 01:06 PM
B
im framing in a door for a closet under neath my stairs, now i will have this small section of wall sticking out. i hope this helps
Old 10-29-12, 01:21 PM
Ah, you want to shorten the width of the wall, right? I was thinking height based on the word shorten.
Old 10-29-12, 01:31 PM
B
yes, the width. sometimes it can be hard to put what needs done into words
Old 10-29-12, 04:16 PM
chandler's Avatar
Received 9 Upvotes on 8 Posts
It won't present a problem as the metal beam is your load bearing member. That will give you a straight across door opening, and I am assuming that is what you want without the "tail" sticking out into oblivion, right?
You'll need to properly reroute your wiring and switching, but I assume you have that under control. Let us know if we can help further.
Old 10-29-12, 04:19 PM
B
thanks sounds good take it easy
