Sound Proofing Tips
Old 11-19-12, 04:09 AM
P
Sound Proofing Tips
We have a small room that contains our infloor radiant heat controls (pump) etc and the hot water tank used to run it. To me the sounds are normal but the wife is a very light sleeper and I am looking for ideas on how to reduce some of the noise. The main noise sources are the tank itself running when needed and the water pump opening and closing to control water flow into the system. The first door attached to the small room is a standard bifold door and the second separating another small room off of this to the main house is a light weight single door. Thanks for taking the time to read this post, system works good just a little noisy for the wife.
Paul
Old 11-19-12, 04:54 AM
Received 754 Upvotes on 659 Posts
If the 'mechanical' room has open studs you could insulate the walls. How tight does the bifold door fit? is it solid or louvered? Is the water tank gas or electric?
Old 11-19-12, 07:31 AM
0
Gas hot water tank; solid bifold door. Room is finished, no open studs.
Old 11-19-12, 07:41 AM
N
Received 20 Upvotes on 18 Posts
Would you have room to replace the bi-folding door with a standard door?
Those folding doors tend to have too much air space below and above them.
Old 11-19-12, 08:45 AM
Received 1,197 Upvotes on 1,152 Posts
How long have you lived there? Most people get used to such noises after a while and they cease to be an issue.
Old 11-19-12, 01:19 PM
Unless I'm mistaken a gas unit has to have a certain amount of air intake so you can't seal the room up tight. A tight fitting door might require a vent be installed.
