Building/Finishing a wall for mounting a tv
Above my gas fireplace the wall is set back/indented for a mantel (see picture) and has a mirror in it. I want to fill in that space so I can mount my TV above the fireplace. I know I will need drywall and paint, but do not know much more than that about how to start this process. Any advice/ How to would be awesome!
Thank you!
Thank you!
There is some kind of bead around the opening. At least take that off. Likely the wall is built up slightly around that bead. So think about shaving some of that joint material off. Select framing lumber that will allow for 1/2" of drywall or a little more. Install the new framing and make sure there is at least 1/2" of recess all around then install the new gypsum panel and tape, finish texture to match and prime and paint.
I like to use steel studs for a little thing like this. I am not a good toe nailer and I just find it easier and faster to use steel and keep everything straight, but lumber is fine. If you use steel make sure you use fine threaded screws. Install wood backing where you intend to mount the screen.
Have you thought about having the TV set in to the wall? You would be limited to that size for the TV, but it might look kind of cool. You wouldn't have to take off the corner bead either.
Whatever you do, do not forget about electric and AV hook ups.
I like the idea of leaving the indentation. It will help with the heat vector triangulation you have to deal with as Nash mentioned. The further the protrusion over the firebox, the more heat and the higher it must be mounted. If you mount a thin TV in the indentation, high enough, you may dodge the bullet. Do you plan on a mantel sitting in the bottom of the indentation? That would be cool. It doesn't have to be deep. Just enough to cover the bottom of the indentation and with ears a few inches to either side of the firebox. Probably out 4 to 6".
