Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Walls and Ceilings
Reload this Page >
Best/Easiest method to remove old layers of paint
Old 01-26-13, 01:54 AM
V
Hello all.
I am searching for the easiest method of removing old paint ? There is about 1-2 layers of old paint on the wall in a room. Is there anything that I can buy at the local hardware store to remove these couple of layers of paint ? I'd like to get to the drywall and go from there.
Old 01-26-13, 04:47 AM
chandler's Avatar
Received 9 Upvotes on 8 Posts
It is doubtful you can remove paint from sheetrock without damaging the sheetrock itself. Our paint guru will be along shortly with his take, so hang in there.
Old 01-26-13, 05:12 AM
W
Just out of curio, why are you removing the paint? If it's oil based and you are wanting to apply latex, use a conversion primer and you're good to go. Scuff sand to improve adhesion first, quick dusting, prime, paint, paint. As Chandler said, it will be virtually impossible to get the current paint off the drywall without damaging it.
Old 01-26-13, 05:20 AM
Received 759 Upvotes on 664 Posts
I also have to ask why
If the paint is peeling you would scrape and then add joint compound as needed. If you want to switch from oil enamel to latex - use a solvent based primer over the oil enamel as Bill suggested.
Old 01-26-13, 07:07 PM
V
Thanks for all the feedback. There is no reason why I would like to remove the old paint before applying the new. I just thought that this would be the best way to go. Thanks everyone I stand corrected.
Old 01-27-13, 04:43 AM
Interior wall paint isn't like exterior paint. There is rarely ever an issue from too many coats of paint. Occasionally the paint will peel but it is generally caused by another issue - not how many coats of paint were applied.
