Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Walls and Ceilings
Reload this Page >
Adding shear wall panels on second story walls?
Old 02-11-13, 12:37 PM
Y
Hi all,
I have a house in the earthquake-prone SF bay area. My house was built in 1951. It's a split-level, 2-story house, with bedrooms above a large empty garage. I'll be doing the usual foundation bolting, shear panels in the garage.
But, I'm also wondering if I should do more, and add shear panels to the walls in the second-floor bedrooms. Currently, the exterior is stucco, with some narrow (maybe 6" to 8" wide) diagonal wood plank sheathing.
There was a long-unnoticed water leak at the corner of a window, and the wood sheathing rotted there (say about 1' x 1' area) so much that they basically turned to dust--I poked at them lightly and they just crumbled.
I know diagonal sheathing don't provide as much shear strength anyway, and that wall already has a huge window (the one that leaked), and now part of the sheathing has rotted out. So all of this got me wondering if I should actually put shear panels on the inside.
I believe that new construction usually puts plywood sheathing all around and outside the exterior walls--is that right? If I add panels on the inside, would that help, or should I really get someone to remove the stucco on the outside and do the shear paneling there?
Old 02-11-13, 09:17 PM
Nashkat1's Avatar
Received 5 Upvotes on 4 Posts
I would consult a local structural engineer - too much depends on the exact situation for us to hazard a guess.
That said, I'll just note that all tectonic shocks travel through the ground.
