Removable wall
Removable wall
I want to finish our laundry room in drywall. However, there are pipes that would have to be covered up. Looking for something that could be removable, like an access the height of the wall and several ft wide. This section would be in the middle of the drywall. Any ideas?
Thanks John
Thanks John
Are you talking from floor to ceiling or an access door like in the link below.
Access Panels - Plastic - 14x29 Access Able® white ABS Plastic Access Panel - Pro Products Sales
Not an advertisement, or endorsement in any way, as I have no experience with this product. But your question made me think of it. Owens Corning From what I understand, it still allows you to access everything behind the wall. Although, it does not appear to be a DIY solution.
Removable Wall
Install 1/4 in plywood with screws. Leave the screw heads exposed so you can find them when you want to remove the panel(s).
