Desperately need drywall expert opinion!!!
I'm DIY remodeling my basement, nothing major just drywall repair, flooring, paint, trim & whatnot. My problem is that I have a half wall with a ledge that's about 4 foot tall running along three walls of the room. One of the walls needed new drywall on half on the ledge wall, and the other wall that has all new drywall is the one that runs the entire length of the room and has no ledge wall, it's the "bare" wall so to speak. The walls that didn't get new drywall have a very ugly thick weird texture to them that also matches the ceiling-it's just lovely- and I know that when I go to texture the new walls the room is going to look VERY different and weird and inconsistant and that is just stupid so I'm at a dilemma of wether or not I should sand or scrape the old walls or just replace with all new drywall? I'd rather not use all new drywall as that's expensive and I'd like to salvage all I can so I can keep costs down on little stuff like that! Any suggestions would be GREATLY appreciated!!! Thank you very much!
-Ashlee ❤
-Ashlee ❤
Depends on whether the wierd stuff will come off. That's where I would start. If it comes off, and the drywall under isn't damaged, or at least not skim coat repairable, then go for it. If the wierd stuff won't come off, then 3/8th in drywall over is the next step. Yea, it's new, and yea, more expensive. But better than going back to studs and then drywalling. That said, how rough is this texture? If it's very rough, you may end up furring the wall in order to attach the new drywall. More expense. Start with trying to get the wierd texture off. And don't forget to add in your frustration level when calculating cost. Sometimes, it's just better to spend a few bucks.
Ok so he thick texture scrapes off and leaves the original drywall in pretty great shape doesn't hardly even rip the top paper. Should I scrape the whole room and ceiling?! It will take forever for sure but I can it why it would be worth it if I could just respray new texture over a scraped wall? Also, I don't know what skim coating is how does that work?
Skim coating is applying a thin layer of joint compound over the entire wall. It will fill in texture or most defects in the drywall. Even after removing the texture that's there might be a need for skim coating or maybe just some touch up here and there. A good way to critique the wall is to shine a bright light on it from an angle. If it looks good that way, then it should look good when it's painted.
almost forgot
welcome to the forums!
almost forgot
Texture will often hide minor imperfections. A lot depends on the look you want. Once all the drywall has the current texture removed and you eyeball it closely you should be able to tell what will be needed to make it look good.
That's what I was thinking too... I'm not really sure what I was going to do for the new texture tho I haven't checked out my options, if I end up havin very many hahaha What should I do?
We'll cross that bridge when you get there. Skim coating isn't all that hard, if you need to you can split the wall up into small squares and just skim a little bit at a time. Once it's all skimmed and dry - sand it all even, check for bad spots, fix them and you should be ready for primer and paint.
The 2 most common wall textures are orange peel and knockdown, the latter will hide more than the former but it's never a good idea to rely on texture to hide imperfections.
