Sticky pads
Old 05-02-13, 06:11 AM
L
Sticky pads
Guys
This is what I need to do and need some help. I live in an apt and need to mount about 20 mason jars (1lb each) which have flowers on them on the wall. I don't want to buy shelving units, etc since this is only a temporary situation
I need something that sticks to the mason jar and then sticks directly onto the wall. The sticky Velcro may work but I don't think it'll stick to the painted wall. Anybody know any products from 3M which will do the job?
Thanks
Old 05-02-13, 06:29 AM
Received 1 Upvote on 1 Post
If I caught one of my renters sticking anything to the walls, that would be a good enough reason to boot them out.
Concider mounting them to something that can be mounted to the wall like a picture.
A small hole would be easy to patch, sticky goo on the wall, not so easy.
Old 05-02-13, 06:39 AM
L
My landlord in fact tells me to use these sticky pads rather than nails. He only wants me to use 2-3 nails for paintings and that's it
Old 05-02-13, 03:32 PM
chandler's Avatar
Received 9 Upvotes on 8 Posts
I believe 3M makes "Command" type hangers that leave no residue when they are released. They hold quite well, too.
Old 05-02-13, 08:41 PM
Received 1,231 Upvotes on 1,179 Posts
Yep, 3M Command strips - I think they're rated to 3 # and there might also be a heavier duty version as well.
Old 05-03-13, 08:10 PM
Nashkat1's Avatar
Received 5 Upvotes on 4 Posts
I live in an apt and [want] to mount about 20 mason jars (1lb each) which have flowers on them on the wall.
If you're thinking about hanging standard 1 qt. Mason jars with gravel, dirt and living plants in them, I suggest that you fill one, give it a good watering, and then weigh it before you decide on the hanging method. It might weigh a bit more than 1 lb.
Old 05-03-13, 08:12 PM
L
guys - this worked well. There are command stickers that take 5lb as well but I really bought the value pack of 48 poster strips and they easily hold up 1lb
Thanks chandler and others!
