gaps
My house is settling, and the ceiling is separating from the walls and the molding. How can this be repaired?
Received 1 Upvote
1 Post
You need to stop and reverse the settling, or your problems will get worse.
This has to be done with a house jack under the floor joists. Once you have the underlying problem corrected, then you can caulk or spackle the cracks in the ceiling/wall and fix the trim.
Good Luck!
Good Luck!
