Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Walls and Ceilings
Reload this Page >
New Kitchen Backsplash. Sheetrock Prep...
Old 05-31-13, 12:38 PM
T
We are having new granite counters installed. The counter installer required us to have the old backsplash removed prior to templating the new one. The contractor removed the old backsplash and sheetrock. He patched back in with new sheetrock/mud.
The old counters are still there and next week the counters will be removed. The problem is that the new sheetrock is not flush with the old sheetrock that is currently behind the counter.
The new counters are a 1/4" thinner and therefore there is a gap some places as big as .25" where the sheetrock taper met the old sheetrock.
What shall I tell the contractor if he tries to lay backsplash over a wall where there is a gap between the new and old sheetrock as well as part of the sheetrock sticking out further than the other?
Will the adhesive make this up or should i require them to mud/sand this gap prior to installing new back splash?
Old 05-31-13, 12:42 PM
Received 759 Upvotes on 664 Posts
Which drywall sticks out further - the new or old? by how much? Does the repair go from one corner to another or does it open up into a wall?
Old 06-01-13, 09:26 AM
T
View image: IMG 0060
Here is a pic taken behind the sink.
Old 06-01-13, 11:58 AM
T
Received 41 Upvotes on 34 Posts
Figure your contractor knows what he is doing.
