Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Walls and Ceilings
Reload this Page >
Merging new sheetrock to already painted walls
Old 07-15-13, 07:25 PM
W
I have some already textured and painted walls and now I have some new sheetrock walls that but up against these old walls. I know how to tape and apply compound but what do I do with the established and painted wall? My thoughts are to sand off a couple of inches of texture and paint so that the joint tape has a place to attach and there will not be a visible seam. Is there a technic to doing this?
Old 07-15-13, 08:30 PM
Received 1 Upvote on 1 Post
Fine to sand so you a flat place to apply the tape to but near impossible to get the whole wall to match without redoing the whole wall with new texture.
Not going to find many textured walls or ceiling fans on most DIY sites.
Old 07-15-13, 09:30 PM
XSleeper's Avatar
Received 1,744 Upvotes on 1,568 Posts
Hard to give any specifics without knowing (or being able to see) what the texture is. You could always include a picture. Are you saying this is an inside corner? If so, you could try flat taping only the new drywall on one side of the corner so that you don't have to even touch the texture... But if this is a butt joint, you probably need to sand at least 8" away from the tape, since at a minimum that's probably how far you will be feathering the butt joint. If it's an inside corner and you want to tape it they way you're supposed to, you will need to sand a minimum of 4", since that's the size of the knife you will need to use on the inside corner.
As Joe said, it won't match perfectly unless you skim and re-texture both walls at the same time. That's why I was suggesting flat taping one side only. It's cheating. You have to use a setting compound, and if it cracks someday, it will just be a hairline crack that can be caulked and painted.
Old 07-15-13, 09:54 PM
W
This is a butt so that is what I thought to sand back and then apply tape etc.. I textured the walls so matching should not be too hard...not sure what you mean by "flat taping" I have had some places where the sheet rock is new below a popcorn ceiling and rather than tape that joint I just filled the corner with mud and painted the wall...again cheating but unless there is movement in the house you can not see any gap.
Thanks guys appreciate the info....
Old 07-15-13, 10:12 PM
XSleeper's Avatar
Flat taping is when you butt the tape up tight to a inside corner (like your ceiling), applying it to one wall but not the other. It's also commonly done up against fiberglass tubs so that the filler between the drywall and the tub doesn't shrink and crack.
Old 07-16-13, 04:16 AM
Received 754 Upvotes on 659 Posts
When you just fill the corner in with mud you run the risk of the mud cracking sooner or later. Flat taping helps to insure if there is a crack that it is at the edge of the tape/corner where it will be less noticeable ..... and can be caulked.
Old 07-16-13, 07:23 AM
W
Understood
Thanks guys the flat tape where the new sheet rock meets the popcorn ceiling will be a better technic than just mudding in the crack. Thanks..
