Help with sound dampening
Could use a little advice with my new house. I just bought a top/bottom duplex and will be living in the basement apartment. I had to gut the whole unit so now have all the floor joists exposed. I want to maximize sound dampening from the upstairs as much as possible. However, the ceilings in the apartment are only 6'6" so I have to conserve as much space as possible. My current plan is just to insulate with R19 between the joists and then Sheetrock over. I was also thinking about putting green glue along the joists where they will be in contact with the drywall. Any other suggestions? Thanks.
How long are your spans? Here is what I am thinking. Can you install some nailers between your joists so that you are not screwing the rock to the joists but between them. Hat channel is probably not rigid enough. 2 X 4's might work The cross bridging might interfere. Steel studs might work. Maybe you you can use 2 1/2 inchers.
Just a thought.
Just a thought.
