Addon - Lower Rafters - Removal / Raising
Hello all!
I purchased my house in 2009, and when I purchased it there was an incomplete room that was really weird. I let a contractor put it back together and called it a day.
Fast forward to now, after getting released from the military I am gung ho about making that room my "Man-Cave" and Wanted to hang a drop ceiling without the tiles, (industrial look);
Long story short, I tore down the drywall and found the lower rafters that the sheetrock was attached too, and want to know if I can raise them up and out of the way (they are at an angle.....) or PREFERABLY remove them entirely.
I took pictures for your viewing pleasure. I removed 2, for damage reasons...oops...my bad on removing sheet rock...lol... and they were VERY easy to remove, and easy to replace I imagine. That leads me to believe they are either non load bearing (directly) or have something to do with sway and wall push or something....
Thanks for the help!
Welcome to the forums Kody!
I don't know if it's the angle of the pics or what but the rafter system looks a little strange. I would expect the lower 2xs are needed to keep the walls from bowing out. The carpenters should be along later with more/better info for you.
