Removing glued drywall
Separated from How to remove drywall from cement wall?
I have drywall glued to wallpaper that's glued to a cement wall. What tool is best for removing?
I've actually used Tide or any other detergent - steam works well - the best thing is like NashKat said - you gotta cut it up and get it open so that you can soak/steam it and get whatever you're using into that glue - no matter what you use though, there's a good amount of elbow grease needed!
