Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Walls and Ceilings
Reload this Page >
What kind of textured ceiling is this? Removing it.
Old 08-15-13, 08:07 AM
Hello Everyone,
I have a question about the ceiling in my garage. My house was built in 1977 and we have an attached 2 car garage. We hate the current ceiling. It is some sort of popcorn ceiling but I am not absolutely certain. The rest of the house has normal flat ceilings.
Here are the visuals.
Garage Ceiling - Imgur
If it is popcorn how thick should it be? Notice the third picture how I took more off because there was a crack in the stuff. I may have to thin coat it after i remove the ceiling.
Thanks
Mike
Old 08-15-13, 01:01 PM
Received 754 Upvotes on 659 Posts
Welcome to the forums Mike!
That isn't popcorn, looks like it's joint compound that was rolled onto the ceiling. It might have had paint mixed in with the j/c. I'd scrape off any thing that is loose, might try sanding [not sure how effective that would be] probably skim coat the ceiling, sand, prime and paint.
Old 08-20-13, 11:11 AM
Well I finally skim coated and scraped the ceiling. Took 3 days to complete. Finished it last night after work and it felt so good. Made the space look bigger. Going to put in the soffits and stuff this weekend. Then I have to decide on a garage wall color. Probably a light tan or grey. Will beat the yellow that it was painted in 1977. Will provide pics soon.
Old 08-20-13, 02:16 PM
I'd suggest using a satin or eggshell latex enamel for the walls. Garage walls often get more abuse than the walls in the house and a latex enamel will stay clean longer than flat latex ........ picking the color is up to you and yours
