Sanding Spackle question???
's Avatar
02-17-01, 08:17 PM   #1
What grit sandpaper should I use? Any other helpful hints to insure a quality job will be greatly appreciated. Thank you.
lefty's Avatar
WA
02-17-01, 11:43 PM   #2
If it's Spackle, and not sheetrock mud, start with about a 120 grit paper using a light pressure. If that seems to be polishing more than sanding, go to an 80 grit. If you actually used a topping or a joint compound, then 36 grit works just fine.
