Exterior siding
's Avatar
02-19-01, 08:48 PM   #1
I have vinyl siding on the exterior of my house and right below my doorway the section of siding is starting to bow out. I am not sure if it is due to weather changes or what and I am really uncertain of how to get the siding to stay in place. Any suggestions?
josh1's Avatar
02-24-01, 08:19 PM   #2
josh1
vinyl
check to make sure the vinyl siding isn't bound too tightly by any nails by manually sliding the piece/ pieces back and forth
the key to vinyl is not to nail it tightly so it has room to expand and contract
if this is the problem loosen the nails with a pry bar
hope this helps---------josh
's Avatar
02-25-01, 04:31 AM   #3
vinyl siding is very stable, so i would look at the possibility that there is pressure being applied to it from the ends, or more likely, the saddle/threshold of your doorway is collapsing to certain degree,
hope this helps you! bundy
's Avatar
02-27-01, 05:35 PM   #4
the siding is movable and the collapsing threshold appears to be a possibility. Tell me more. It is a fairly new house.
's Avatar
02-28-01, 02:51 AM   #5
is there j channel and sill trim where teh piece runs under the door? Does the piece appear to be cut properly?alot of times when making door or window cuts the cut man will cut one keasurment all the way across and in reality its not the same ex.left side 1-1/4 right side 1-3/4.if he cut it all the way at 1-3/4 willl be too tight and will bind up just a thought used to work on mobile homes a million years ago and saw some pretty shoddy siding work from the factory
's Avatar
02-28-01, 10:16 AM   #6
if there was a way to look at the doorway construction from underneath, in a crawl space, i would check if there has been a break in the timber or the builder might have cut some corners!
