had to cut hole in ceiling
Old 10-16-13, 10:55 AM
Question had to cut hole in ceiling
Hello,
I had to cut a hole in my laundry room ceiling. The hole is through the sheetrock into the space between the ceiling and second floor subfloor. I was contemplating covering it with a nice lookin fan grille or vent grille so I can keep it for an access to the area. Would this typically violate fire code? Thanks
Old 10-16-13, 12:51 PM
Received 1,197 Upvotes on 1,152 Posts
That should be fine. There are also access panels you could put in the place as well.
Old 10-16-13, 02:43 PM
Received 1 Upvote on 1 Post
