Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Walls and Ceilings
Reload this Page >
Help with replicating this ceiling texture style
Old 10-25-13, 07:36 AM
P
I'm planning on putting some lights up in the ceiling and will have to patch my ceiling and was hoping to get a few second opinions on what technique is used to get this texture affect on my ceiling. I think it was done with a trowel or blade and then flattened out. I'm by no means an expert though and wanted to try to get some feedback to see if this sounds about right.
Old 10-25-13, 10:22 AM
Received 785 Upvotes on 688 Posts
Welcome to the forums!
It's called skip trowel texture. You'd want to thin some j/c down and then apply it with a wide knife or trowel. How big of an area do expect to need to patch?
Old 10-25-13, 10:56 AM
P
Most likely small sections, maybe 6"x4", just enough room to get some 12/2 wire through through. Probably 5 or 6 of them. I'm going to have to cut out a few small ceiling sections to run some wire up there. I was trying to avoid any ceiling work, but the way my joists run in the room, it's looking easier than the other alternatives.
Old 10-25-13, 11:00 AM
As long as you avoid building the repair up [thicker than the rest of the ceiling] it shouldn't be too difficult to make a hard to spot repairs.
Old 10-25-13, 11:08 AM
P
Thank you. Only method I've ever done is with a mop/brush stomping it, and trying to get a close match was always a bear. This looks a little easier and forgiving I'm hoping.
Old 10-25-13, 11:11 AM
Received 1,229 Upvotes on 1,178 Posts
Not a bad idea to practice on cardboard or other scrap material to perfect your technique before moving to the actual ceiling.
