Cleaning up Drywall Dust
Old 11-20-13, 11:49 AM
V
Any tips, tricks, secrets, etc... for cleaning up drywall dust? I need to get it off the walls/ceilings before I apply primer. Also need to clean up a concrete floor that has a nice thick layer of it. I feel like I am just recirculating it whenever I try and use the broom to get it off the walls/ceiling.
Old 11-20-13, 12:22 PM
Received 1,197 Upvotes on 1,152 Posts
I use the shop vac a lot.
The broom should at least dump it to the floor instead of the wall or ceiling.
I've heard of some using a tack cloth as well.
Old 11-20-13, 03:47 PM
T
Received 41 Upvotes on 34 Posts
On the floor use sweeping compound. If the big box stores don't have it a janitorial supply place will.
Old 11-21-13, 04:39 AM
Received 754 Upvotes on 659 Posts
I've always used my push broom [minus the handle for the walls] You don't have to remove 100% of the sanding dust but you do need to remove most of it.
